Help google not connecting
Hello :)
I have a Samsung Galaxy S3 GT-19300T. Last night, Google Play Store stopped working. I've contacted both Google and Samsung (both of whom basically repeated what people on the web have suggested on how to deal with this problem), cleared cache, cleared data, ensured everything that needed to be enabled were enabled, used several different sources of data (a wifi and two phone datas) and even did a factory reset.
Nothing has worked, and yes, internet worked on all the data points I connected to, and my password was correct when I was prompted to reconnect after the reset.
Any help would be greatly appreciated, and thank you!
Im sorry if this has already suggested mate but if you go to Settings, Applications, hit the ALL tab at the top, scroll down to the very bottom of the list, are there any apps that say "disabled" next to them?
EDIT sorry to f*** you around man. Just noticed youve done a factory reset so ignore what i said....
Next thing id suggest is to reflash the phone.
If you have a carrier shop or samsung repair center nearby they could do it or we could talk you through doing it yourself :thumbup:
