How can I eliminate this "Google Services" battery drain??? It didn't start doing this until a few days ago and it is getting worse and worse!!
Just for you info,
Google Services consist of multiple services, such as:
Google Contacts Sync
Google Bookmarks Sync
Google Account Manager
Google Services Framework
Google Play Services
Network Location (location reporting, location history, location sharing)
As pointed out in earlier reply, PLAY (4.1.6 version) has been reported to cause battery drain, and the recent update, which is rolling out as we speak, supposed to fix that. That however, was effecting smaller group of people, which I believe is part of a combo of telco and OTA updates.
The other notorious service, behind battery drain is "Network Location service". Beside screen, that's probably second most battery consuming background process, which is responsible for location sharing, history and reporting, for various apps, not just google. If updating the PLAY didn't improve the battery life, you might want to disable location sharing and history for apps, which you don't need to use it with. Like Facebook, G+, Maps, Instagram, and whatever app you can find, that allow such setting change.
This should result in (almost) immediate results. Also, if you are not using Google Now, turn it off. Now is a decent battery hog.
