Google Voice: How do I use it to replace sense dialer call screen?
Evoke
I don't like the sense screen that comes up when you make calls, and I have google voice installed. How do I make sure that the google voice screen, pictured below, sticks instead of having it switch to the sense call screen. Also, can I theme the google voice app? I'm not a fan of the colors.
Question back to you: Does the Google Voice screen actually come up in your call? I have G.V. and I haven't seen it come up. With me, it just has a box that comes up and says that I am dialing through G.V. I have had GV since I got a Hero last October.
I thought that the sense screen was just part of the operating system. I suppose there could be an overlay for the dialer, buy I have only seen those in rooted phones.
It does come, and then the Google Voice Screen goes away and the Sense screen replaces it. The box you mentioned also appears.
i have my GV set up to call international numbers only, so when i call a number from my contacts (international) then the GV dialer opens, but it does gets replaced by sense dialer.
I have the same problem. It flashes for a second (regardless if I use the GV for all, none, or prompt) and then the HTC dialer takes over. EVO.
That's not the Google Voice dialing screen, its the standard Android one. That's the exact screen that showed on my Moto Droid when I would make calls. (With or without Google Voice) And the reason you see it momentarily is that its buried deep in the OS, but the Sense overlay takes over after a moment. There is no way to get that screen permanently with a Sense phone.
I have Google Voice too and i'm pretty sure the Google Voice dialer shows every time I make a call but it shows as a little box that says somethin like "calling from" and then it displays the number then it goes away. I have it setup so that ALL calls are made via Google Voice...
