its simply a connection issue that happens with all of my android devices. at one time or another there is a momentary lapse in data connection and that causes the voice transcription to be inactive.
I love that you used your Note to illustrate your question. I only see this happen then I wake the phone and try to send a text too soon after, since I have Juice Defender set to turn data off while sleep.
I get it sometime when there is really no internet connection or when connection is really bad. It never happens when I am at my home with wifi.
so this doesn't seem like it's a wide spread problem for anyone.. ?
There is a know problem with Jellybean when trying to use Google Now and Voice to Text while connected to something via blue tooth. If you are in your car and connected to bluetooth phone, you can enable "touch sounds" (settings / sounds / touch sounds) and google now will function. If you want to use voice to text, you will have to disable the bluetooth audio function. The bluetooth phone can still be connected but voice to text does not work while bluetooth audio is on. Hope this helps
