Help Googles widget theme not changing when applying different theme with ADW.....HELP
bobbybv15
Hey guys I have an optimus m with the sense rom which comes with ADW 1.3.3 now when I try to apply a new theme everything changes except for the Google widget. Is there something I'm doing wronge? Can someone explain this to me? Thanks
You go and select theme and apply it and the google search widget doesn't change?
whenever i tried it it always remained the same. i think if you head over to xda forums there are .apks for the google search widget that are customized. Using CM7 with the theme changer solves that issue for me though and im currently running a black/transparrent google search widget
Thanks for the help but before getting the sense rom I tried cm7 and it ran terrible on my optimus m.
It didn't change with the theme because the google search widget is in a way specialized and can only go certain colors. Therefore, it wont change with alot of the themes. Try a different theme.
Hope this helps.
XDA forums definitely has custom Widgets posted over there by different users. This includes the Google Search Widget. Go check them out maybe what you need
