Help Gorilla glass?
Not as quick a question as you may think.
It has "scratch resistant glass" made by Corning (who make Gorilla glass) but there is no actual mention of "Gorilla Glass" in the specification.
All Corning electronic glass is scratch resistant as a point of practicality for handling during production and handling.
It is not Gorilla glass, else they would be marketing the feature.
Thanks. Searched Google but couldn't find out. Is it not as tough then?
Do I need s screen protector also?
It's not as tough, but it's pretty close. If you're going to carry it around without a case, you might want a screen protector.
I opted for a screen protector that's made out of an 1/8 inch thick hide from the elusive nauga. On and off in a matter of seconds.
FYI, even Gorilla glass is not shatterproof. You should find a case you like, just less to worry about.
True dat. Energy has to displace somewhere and glass is usually the weakest link- Gorilla or not. Exception being a really cheap or non sturdy build. The more rigid, the more likely the display is where stuff breaks.
Thanks very much for the replies. Will go buy a case. Problem is you can't get to the edge of the screen to edit when you are typing using one
You've been looking at the wrong type.
Try this:
Amazon.com: MoKo(TM) Slim-fit Cover Case for Google Nexus 7 Android Tablet by Asus, Black (with Automatic Sleep/Wake Function, Protective Hardback, Built-in Multi-angle Stand, Elastic Hand Strap, and Stylus Loop)--Lifetime Warranty: Computers & Acces
This exact case is sold on Amazon under different "brand names". There is no problem at all at the edge of the screen since it only holds by 6 secure points, four of them the corners. I like this one so much I bought another when I got another Nexus 7
Try this:
Yeah, the one I have been using is the full surround by Moko, it can make pulling the notification bar down difficult. But safer with the kids. I just take it out of the case when I use mine.
i wonder if the new one will have gorilla glass..
i doubt it because of the cheaper pricing compared with other tablets..got to save money somewhere
Well, it is Corning.
Screen
7.02" 1920x1200 HD display (323 ppi)
1080p HD IPS
Scratch-resistant Corning
I've had my original Nexus 7 since they were first released and to date it's scratch free. That's being used without a screen protector. I will be buying a new Nexus 7 when the LTE models are released and I will not be installing a screen protector on that one either. I just can't stand the things :D
