Help GOsms pro problem
mted558
I'm using GOsms pro widget locker, not sure if it's an issue with the combination of the two or not but I've noticed that when I get a text message I get a blank message first that says from "unknown" and always has the same time then I have to scroll to see the actual texts I've received. Anyone have any ideas about this? I really like the program but I did uninstall it and used the stock for awhile and didn't have the problem. So I re-installed it and now having the issue again. I would really like to be able to fix it if possible. thanks!!
