FIRST THINGS FIRST!!!!
P.S: I BRICKED MY 2 DROID RAZR M'S... AFTER 4 MONTHS I FOUND OUT WAY TO UNBRICK RAZR M WITH BOOTLOADER LOCKED
YOU SHOULD FOLLOW ALL STEPS!!! ALL
Requirements:
A Computer
A wall Charger
A data Chable
Downloads:
(SEARCH IN GOOGLE IN WHICH LINKS ARE NOT GIVEN)
Driver Easy
RAZR M- KITKAT FIRMWARE (MUST)=== you can get from sbf.droid-developers.org
MOTOROLA device manager
RSD LITE 6.1.4====think RSD LITE wont work for you? just shut up and follow steps you will see how it works!!!!!!!!!!!!! (even rsd shows your device as N/A it will work)
STEPS!!
1= install motorola device manager
2= download and Install Driver Easy
3= Download and install RSD lite 6.1.4
4= PLUG YOU phone to computer with data chable
5= open driver easy
6= scan for drivers
7= click on get drivers
8= FIND ADB driver (can remember fulll name but was ADB interface or Something with ADB)
9= Click on download
10= Install it
11=DOWNLOAD RAZR M KITKAT FIRMWARE!
12= extract it Somewhere in computer
13= After extracting, edit .xml file with Notepad
14= delete all lines which contain " GETVAR" and "OEM"
15= click on X then and click on YES
16= open rsd lite click on "...." button
17= select that xml file
18= click on "flash"
AND WAIT IT WILL complete and your phone wiill boottt up and ll take sometime at droid eye! and ll boot up!
It will not give any kind of error!
dont forget to say thanks!
and also you can ask about errors below
Requirements:
A Computer
A wall Charger
A data Chable
Downloads:
Driver Easy
STEPS!!
5= open driver easy
6= scan for drivers
10= Install it
