Reporting on the 1500 I got from BidAllies: I am at 40 hrs up time and 4 hours 30 min awake time with about 30% of the battery left. That is about 50% better than I got with the original battery.![]()
Jeez, that is better than I've ever gotten and I thought my battery life was pretty good. What's your secret?
Yes the door snaps close, you just have to go around the entire phone on all corners and sides, mine closes fine, I don't see any gaps.
I do have some creeky near the optical button but since I don't use the optical button it doesn't bother me.
I've had my 1500 battery for about a week and now the back snaps fully closed.![]()
how is the improvement in battery life so far?
im not worried about biggger battery I want it just so the back door doesnt creek!, does the 1500 fit without any gaps and everything nice and easily or does it have to be forced. i can live with stock if it needs to be forced. but if not i need this.
For me its about 25% better with my daily light use. All I was hoping for was it to last thru a day out shopping (medium use) and it looks like for $15 it will do that.![]()
so on a full charge you are consistently making it through a full day of use?
See this is what I'm afraid of, I'm reading mixed reviews. Some say the 1500 mAh battery fits perfect without any gaps and gets rid of the creek from the stock battery, which is why I want to buy one. But I don't want it if it is not going to fit correctly...
Was going to get my Bidallies 1500mah battery but then I found this. 35.00 (38.00 shipped) for 2 1800mah Batteries (awesome!) + wall charger (meh).
Amazon.com: Sprint HTC EVO 4G 2x1800 mAh Battery Longer life than OEM+ Wall Travel Dock USB Charger also for Verizon Incredible Droid Touch Pro2: Cell Phones & Accessories
One of the reviewers (has the Evo 4G) even did a mah test saying this:
"I have an battery mah tester and I can tell many companies claim there batteries have certain mah but dont Stock 1500mah seido 1750mah and this battery 1800mah I tested all three Seido mah was 1340, Stock battery was 1414mah, and this 1800mah battery at 1730mah, which is great with this battery I'm getting 20-24hours with average use. An huge difference is when I take my phone off the charger usually the other batteries drop from 100%-90% within a couple of minutes, but with this battery that problem no longer exist sometimes I can go 2-4hrs before reaching 90%."
those numbers sound pretty good to me, some other reviewers are using them with their DIncs and are happy so I figured I'd give it a try. And as a plus it's a red battery like the stock one so on a icing on the cake level that makes me happy. I'll follow up with updates to let everyone know what my numbers are like.
Does this fit with the stock back cover?
Hey guys, so is it safe to say that you all think that Bidallies 1500 replacement OEM battery for the TP2 is better for the Incredible than the 1500 and 1700/1750 from Seidio. Please advise. I'm about to buy my first replacement battery. Thanks.
Is the BidAllies 1500 supposed to be black?
I just want to make sure I got the right one.
It appears to be working swell![]()
