HarleyChick
Used the SD method to put Froyo on my NC and it is fantastic! Was just wondering - I don't mind it being on my SD Card, but if I want to move it to the internal memory, what's the process?
First thread in this Sub-Forum. Check the first two links and read VERY CLOSELY!
http://androidforums.com/nookcolor-...n-nookcolor-updated-2-7-2011-11-11pm-est.html
Thanks for the quick response, bg, but I'm not sure that this is what I'm looking for. I did as you suggested, and read through both of the links (wiki page, and autonooter), and they don't mention anything about putting Froyo onto the internal memory. If they do, it might be in jargon or lingo that I'm not getting.
And I should say that the only real reason I would want to put Froyo in internal memory is it is a bit laggy off the card (I'm using a class 6 8GB card). And I still want to be able to backup to my sd card (from TiBu), and I'm not sure I can do that with Froyo running from the sd card. Okay, that was 2 reasons. Am I mistaken about the backup?![]()
You can still do backups from Titanium using the sdcard.
Update? Did that method work for you, Harley?
