Help Got OTA Froyo now Home key doesn't work
Brian2071
I got my OTA Froyo update and now my Home key doesn't work right. First, if I am on any of the numbered home screens (who knows why they decide to number them now) and I press the home key it takes me to screen number 2, not the main home screen which is 4. Even if I'm on the main home screen and I press the key it goes to screen number 2
Also, when you are in any application and you hit the home key it takes me back to the numbered screen I was on last, not the main home page.
Is there any fix or work around for this?
To set what home screen you want it to go to when your not on the default home screen, on the home screen, hit menu then edit, then you will see all the screens then click "Set Home" to whichever screen you want it to default to when you hit home.
As for the other question, I don't think that is a possibility, I mean it could be but I've never seen it before.
Hope I helped!
Hope I helped!
That did the trick! Thanks!!!
