Got replacement EVO, signed into Appbrain and got screwed?
gear.h34d.2012
Hey guys, so basically topic. Just got my replacement EVO today from the Shack and just started the process of recustomizing it to where I want it. Unfortunately I've hit a snag. I downloaded Appbrain and installed it. Upon signing in it auto-sync'd and now I believe all of my apps sync'd from my old phone are gone.
Basically:
1) That sync system is extremely non-intuitive.
2) Please tell me theres a way to get that list of apps back because I REALLY don't want to re-buy all of those apps. :mad:
Thanks guys.
~Cheers.
Basically:
Thanks guys.
~Cheers.
If you had a backup app, just log into that and your paid apps should return.
Look for "Your app lists" on the left hand side.
One of the list will be Apps On phone, see if you have anyother apps list. If you don't then yes they're gone.
Next time make sure to create a Backup List "I know that bites, I had to learn the hard way too".
I've done like the previous poster said and I just use Astro and backup all my apps as I no longer use AppBrain.
Patience my friend. Will make easier. Also, remember, all paid apps still listed in market.
Debra got her replacement yesterday. Been 24 hours of getting right again for her.
