OK, I got root to work(adb Rooting).. read everything and did everything correctly but the firmware shows 1.03.605.10. is there a way around it to get firmware 1.12.605.6 without losing root?
It sounds like you downgraded correctly but didn't flash to the current firmware correctly. As long as you have S-Off, you can repeat all the steps in the rooting guide to re-establish root after you flash forward.
Glad you got it worked out. I remember reading that now,but it dint that the firmware you were refering to was the older version mentioned in the xda thread. for some reason i only recognized the ".10" part of it wich is greater than ".09"
ayway,i changed my other answer so anyone searhcing this later wouldnt get confused, or think its ok to leave this version on.
