Root GPS.conf
bg4m3r
Android Expert
Could someone upload the stick GPS.conf file, preferably from z3? My gps has crapped out, I think partially due to me messing with the conf file.
Is anyone else having gps issues?
Well that didn't help. :/
GPS Status says 24 sats available, but I'm only getting 1 fix at best. I've recalibrated the compass, cleared the gps cache, even downloaded assistance data. Just wiped dalvik and system cache too.
Anyone have any suggestions?
If all else fails, I'm going to reflash everything.
Have you tried fixing your gps.conf file with FasterGPS (can download from play store)?
https://play.google.com/store/apps/details?id=org.fastergps&hl=en
Download and install. Only change the NTP server setting. Select "North America", of course, "USA".
I don't know if this may help or not.
Spunky168
I've added the servers myself already. Not FasterGPS, but something similar is what messed up the conf file to start with... It wiped everything out of the file except the server list.
Installed FasterGPS, it's working now. :) I had tried it before, but it was crashing when I tried to set my country. Thanks fit suggesting it. :)
Glad to hear it. Knock on wood, but I have been using FasterGPS for years and never had any problem with it with my SIII, Galaxy tabs, and now my LG.
Let me know what settings you use that works best for you.
Spunky168
Spunky168
Honestly, I'm not real sure what all the settings effect and haven't had time to look into it. I just set the location stuff for now.
you guys helped fix my GPS too. I downloaded the cfg and copied it. Nada. Downloaded fasterGPS and updated region. Nada. Downloaded GPS Status and Toolbar. It downloaded something and voila! Tons of sats and instant lock on GPS only location. THANKS! I think it was everything I did that fixed it as Id run GPS Status before and got nothing. I was going to order a new phone from Amazon and downgrade this one back to stock V3 and return it lol. This was a really pervasive problem as itd lock up my data connection and require a reboot to get data back if at all until the phone saw fit. This was a bitch on a recent drive through the least populated and rugged part of the country.
