My GPS is not establishing a link to the satellite ever since the Froyo update. I have tried on a clear sky area, for more than half an hour & still it doesn't connect at all. Has any of you encountered the same ?
mine took a while so i changed the settings once and it worked after that try this
menu
settings
location
use wireless networks & or use gps satellites ( i didn't have this ticked )
connect to wireless and go next to windows and try it then then turn wireless of and restart phone and see if it works with just gps you need a internet connect with google maps though but dont use wifi.
