Just noticed that the icon/gps switch is gone from the screen. It was located on the page where favorites, 4-g Bluetooth switches are located. not able to find it as a shortcut/app or widget, any ideas?
From a Home screen page that has available space for the GPS icon, tap the "Personalize" icon. It is just to the right of the "phone" icon. That takes you to the "Personalize" page. Tap "Widget". Then tap "Settings" (this is Widget settings - NOT normal settings)
Then tap the "GPS" icon. It will put the GPS icon back on your home screen page.
I found this on the HTC site, I guess I'm not the only dummy to do it
