johnny124
Recently I was having major issues with my GPS. It was showing me on the wrong streets, had trouble finding a signal, and kept directing me the wrong way. After alittle research, I found a way to reset your GPS so to speak. I did this and it has fixed the problem.
First, get the MSL # and write it down
Then open up your dialer and type in ##GPSCLRX#
This will open up a box for you to type in your MSL number.
Your phone should reboot and gps will work much better now!
