posted the following in the general issues, but worth noting here too.
My Main issue is GPS.
- 3 times it overheated using GPS while mounted on windshield, phone would simply refuse to charge when phone temp went over 43oC. Outside temp was between 90-95oF and sunny.
- Phone gets very hot just simply using the GPS
- Cant get a GPS lock at all indoors
- Looses GPS lock while driving, Db ratio for even 7 sat locks is medicore
- Whenever it tries to lock in GPS, data gets dropped from 3G to 1X like there is interference between them
I think the phone is working very hard to get and keep the GPS signal, which is causing so many other issues.
OV GPS made the phone warm and I even had a silicone case on it and never exp these kind of issues with it.
Course of action, going to get a replacement unit and hope for the best.
Just hoping I am not going to fix GPS issue and get 10 new different issues from the replacement.
I've had hit or miss with the GPS lock, even with the use of GPSfix. I'm not really sure what the issue is, but klehman, if you could test this over the course of a couple weeks and then respond, that would be appreciated.
I guess we also had some issues with solar flares and GPS interference, so I always did my GPS testing with my Optimus V and Triumph side-by-side. The OV has basically been perfect with GPS lock in less than 2 seconds, 100% of the time (even indoors).
