gps location software lag
codral
Hey so I downloaded the maps for location, for aus, and can bow access them wgile offline, which is good but... It's quite laggy... seems ok when zooomed in but once out it lags right up. Has anyone fixed this? I don't think It's a hardware limitation as my n95 I had previously had a maps app that looked about the same and performed about the same also... cheers
locations app isnt the best on DHD, and i faced the same problem too when i used it a couple of times. but since then i have installed sygic mobile maps and it is good without any lags. in fact, i had a feeling the gps wasnt performing well whilst using locations but realised the problem wasnt the gps but the app. install the gps test app and you will understand what i am saying. i get a gps lock in less than 10 secs under clear sky and sygic is good. apparently copilot is also good on DHD...
