Clambake12
GPS worked fine when i was running Cognition rom. I flashed back to stock cause i was not a fan of the version of the rom, ran Titanium back up as usual (backed up missing apps and data). So all went well with flashing back to stock, but my gps gets no lock at all can,t even find a satellite, even when left on for hours. So i Master Clear, check my gps with Gps Status, and i pick up a lock fairly quickly. Run Titanium back up and im right back to where i was with not finding sats at all. I'm assuming there are files that got backed up that screwed up my gps.
Now on a side note i should also state that i tried the Plum-bobs gps fix found on xda developers site. I tried this after i flashed back to stock the first time when i noticed it wasn't working, so not sure if this is the problem. Also im pretty sure the rom i originally had installed contained this same fix, could this be a problem and if so anybody know what i need to do to fix it. Maybe just backing up Apps only and master clearing again?
