Yeh, I forgot to say that!Check setting > location and make sure gps is turned on. If that's not it, then you probably do have have a hardware problem........![]()
Update:::::
I fixed my gps by using agps patch v1.2
I found this patch in wildfire s forums
Now my gps is working fine.
