Anyone? Or shall i take it back to cpw?
I wondered if we would start seeing GPS complaints.
and now it's not working again!
so no point in going from good to bad, really wanted a dual core phone though lol
hmmmm!!! looks like square one with the gps issues then :-/. might not buy one after all, think im going to wait for nexus 3. I use gps alooooooooooooooot! and on my desire HD is really goodso no point in going from good to bad, really wanted a dual core phone though lol
Great another great on paper, DOA phone from samsung...
Hopefully they get call quality right this time around (noise canceling mic?).
Well, it gets more curious by the hour. About to return the Sg2 tomorrow, so as a last resort I called o2. A real nice chap called Gary looked at my tariff and said that whilst I was on a Simplicity tariff, it was an IPHONE tariff, and as such I had the wrong APN settings. This would cause my Sg2 to intermittently lose data connection - hence my problems. He has reset my tariff and given me the correct APN settings for the phone which should come into force at midnight tonight. Also, after looking at my data usage online at the 02 website it says I have used 225meg of my 500 meg monthly allowance ALREADY ! In 5 days !
Seems like although I enabled wifi, and telling me I was connected to wifi, I was actually connecting and downloading apps etc via data and not wifi because the APN settings were wrong. Seems strange as the download speeds were blistering - an app downloaded and installed in less than 10 secs?
So, I'll post back here tomorrow when and if these new settings work. I'll take the car for a test drive in the morning and see if the problem is rectified...................... or not.
Basically, if this works, then the sg2 may be a keeper. If not..... bye bye. It won't take long to find out... stay tuned folks.
PS, seems like a lot of SG2's are coming out with either the wrong APN settings or none at all. Please make sure you have the correct ones for your phone/tariff. Fingers crossed.
.OK. All fixed and keeping the phone. 3gs has been lent to my daughter.
Here's what happened and what changed my mind. Basically, I've got the phone working as it should in all respects. GPS locks in quickly and is very accurate using Sygic. ( not sure whether to keep that or get co-pilot live, but Sygic is very good indeed). Wifi now syncs at 4-6meg, tested in numerous places with speedtest.net. Data connection issues solved. It really was all very simple - it's the APN settings. You HAVE to have the correct settings. Apparently the phone is designed such that the GPS and wifi won't work correctly without the correct APN settings, it's a Samsung design thing, so I was told.
After inputting all of the correct settings ( Important- along with the correct tariff), the phone transformed into all it should be. I've had no data errors, no wifi errors and the GPS locks in from cold in 5-10 secs and is super smooth and very accurate. I can post my settings here if anyone is on O2, but the trick is to call your carrier and enter the APN settings over the phone, or go to your local carrier shop and get them there, but make sure ALL fields are fields are filled out, I had a few missing and it wasn't until I went to the local O2 shop that we could fill out the missing details. They had all the settings on their 'puter for the Sg2. That's when everything came right.
Good luck to anyone having problems, I'll be happy to tell anyone my settings if you're on O2.
Phil
Phil
