I wonder why nobody answered but OK. Look in Android prefereces. There is an submenu with Security and position or so {I don't use english localisation}. First option is Assisted localisation and seccond is pure GPS. Just turn off assisted localisation and that's all!
I just tested it at sea. It works quite well and was quick to find a satelite.
I think it is often more a question of the map applications being rather strictly configured to use a-gps... much because they are made for downloading the map image at the same time...
i use NavDroyd...
the best nav tool for me cause of the offline search...works almost perfect in Asia...
definitely worth the price!
check it out here...
