GPS is not an added cost. Unless you're referring to ATT navigator, which is a ripoff and costs like $10/month. The google navigation software is free. Is that what you meant?
GPS itself doesn't use data, but a GPS-enabled app might then pull in data for its own purposes.
Example would be Google Maps, which takes the GPS info and then downloads map data to display. The GPS location fix info itself though doesn't involve downloading data. It's calculated from the satellite signals.
