SSV3NOM316
On my Incredible running 2.2 (OTA) w/ Launcher Pro+
While using the navigation... 1 of 2 things happens...
#1) After using the GPS for a while (any where from 15 - about 45mins) The phone just restarts out of no where, doesn't matter if I am holding it
or not. It can be the first app I turn on, with no other apps running. And some
times this restart goes into to a "looping" restart. It'll just keep poping up the
white htc incredible screen, then go into the new red droid eye boot
animation, go blank and then go into the white boot screen again. Until I do a
battery pull it won't stop.
#2) The navigation will be working all fine and then out of no where just exits,
without the phone even being touched. Then I'll have to open up the navi.
app again and select the most recent destination...
I have never rooted the phone, and I am on the OTA 2.2 update.
Just wondering if any one else has a had this problem or similar?
I'm going to be doing a factory reset probably tomorrow.. and see if it makes
any difference.
Just a quick checklist...
Use app brain to save all apps that were previously on the phone
Make sure all images are on the SD card
All contacts saved to google account
Launcher Plus homescreens saved to SD
I guess thats about all the backing-up thats needed?
any difference.
