Go into the settings and where the usb debugging is the next question say allow mocking you need to un check .
I believe the arrow points north. I'd never noticed that before.
Isn't it supposed to point in the direction you're facing? It has before IIRC.
The arrow on "you" is supposed to show which direction you're facing.
Do you have an S-View cover?
If you do, then take this off, as this greatly interferes with the device's compass.
