GPS signal issues
R1OT
Member
I've noticed within the past month or two my Eris has been having a hard time searching for a gps signal. I'm on the Leak v.3. Sometimes it takes a matter of a min to lock on other times much longer, and this past weekend I had an indecent where it never found the signal for about a 1/2hr or more. :(
My refurb came yesterday for exact same problem.
For the past couple of months, more and more often it has been sitting at searching for satellites permanently. Over an hour on multiple occasions, including a restart. Was on other side of the state, and GPS did NOT get a fix. Almost made me unable to find my job site.
Next day went into verizon, and it did the same thing in store. Go in and get it documented every time it refuses to so it'll be less of a pain if you get a refurb for the issue.
Had same issues and after researching found Advanced Task Killer to be the culprit for me. Do you have Advanced Task Killer installed ? If ATK is running kill that app and try testing your GPS signal.
