Hi!
I have a problem with GPS. It works fine, but only through some time after turning on my phone. I mean that all apps using GPS work correctly until... any GPS app stays in memory. It hasn't use GPS actively - it's apparently enough to have something common with GPS in its own settings. All apps use GPS with no problem in this case. But if only all apps using GPS are permanently closed (this in memory too) problems appear. Any app which uses GPS can't activate it. Apps showing GPS satellites show nothing. Google Navigation shows only "Searching GPS" info, but nothing happens. GPS icon only blinks - appears and disapears: it looks like app trying activate GPS but with no success. Problem is being solved by turning phone off and on, but only for some time... I tried resetting: AGPS, Google Maps and phone, but it didn't help. It looks to me, like some kind system error caused by incorrect resources management, because GPS isn't available to apps more than one time.
Best regards
LeHardi
Best regards
LeHardi
