IrishPilot
I have come upon the most aggrivating problem with my EVO and wanted to see if anyone else has been having the same problem.
If I turn the GPS on and try to use the phone for navigating, it inevitable will restart itself continuously after 5-10 minutes or so of use. At that point, it will restart over and over. Try to make a call after it restarts? Restart. Try to use nav again? Restart. Never fails. I have been testing it the past couple of days and it seems to happen only when the gps signal is turned on, and after a couple of minutes of use.
Anyone else find this? It is infuriating when you are trying to use the Nav and the damn thing starts resetting right when you are in a downtown metropolis trying to find your way around. I basically had a useless phone for like an hour. Until I figured out it was the GPS, it just reset itself over and over for an hour straight...it seemed there was nothing I could do to stop it...if I touched anything, it would immediately restart.
