DroidX rooted via Pete's, original ROM
Too often, a root-only app runs only after two tries. When I tap the icon the first time, it wants Superuser permission. Permission is granted, then the app works properly. Sometimes it's just part of the app. For example, the brilliant Button Savior works perfectly except for the OFF button, which needs TWO taps - the first is Superuser.
And there's no Superuser app visible, though Market says it's "Installed" and root-only apps work, but not all of them work properly.
There's probably some simple thing that's missing - but what??
check your frozen log and see if you did accidentally freeze it.
