Boot with it plugged in. Works fine.
I already noted this upthread (and I think someone else did, too, but that might be another thread) -- although I'm glad you mentioned it again, because it raises the issue of what the hell is going on here.
Because it's more than just that. My Samsung supplied charger (with Amazon extension) absolutely will charge without having to reboot. 100%. No problem. It will pick up that charger on the fly.
It will also pick up an Amazon Kindle 9W charger on the fly. (A discovery I made by accident.)
I have two Motorola charges which used to work with the phone all the time. After 4.3, it will sometimes pick up one of them on the fly but not the other; although it will charge with either one if I reboot while plugged in. (I see no difference in the specs of these chargers, although the one it likes less seems to have a slightly thinner cable.)
So, yeah, there's something in 4.3 which makes it more picky about what it will charge with, but the problem does not occur if you reboot while plugged in.
That's messed up.
