This past week I have been having an issue with my GS4 randomly shutting off despite having plenty of battery. A week ago, the phone shut off and wouldn't turn back on until I plugged it in to charge and left it for a couple minutes. The battery was around 60% at the time.
I figured maybe it was just a fluke, but yesterday it happened again. The phone was sitting idle for probably about 15 minutes when I picked it up to find it had shut off. Then it shut off two or three more times while I was using it. I wasn't playing games or doing anything that would have been stressing the battery. All of these times the phone turned right back on without charging. Again, plenty of battery.
I've done a little searching and I've read people saying it's probably a bad battery because Samsung had issues with some batteries swelling. Mine appears to be fine though.
Samsung told me they think it's the battery or the charger (I'm using a Verizon charger because that's what they sent me when my Samsung charger broke). Verizon says it's most likely the phone, not the battery. Tech support ruled it was the phone because he had me shut my phone down and take the battery out while it was charging and said my LED light should have stayed on. (What?! I don't have the LED set to be on during charging anyway.)
Should I assume it's a bad battery? If so, are there any non-Samsung batteries you would recommend (Anker, etc.?) or should I stick with a factory battery?
