I've been running GSB for a long time and it's fine ... but over the last 3 or 4 updates the lag issue using LP has been getting noticeably worse. Combine that with the fact that the GSB developer seems to be losing interest in the project, and it means I'm moving over to Condemned as soon as its next upgrade comes out.
Good choice.![]()
The only drawback I see in GSB is the lag when hitting the home screen from an app or another screen.
I rooted yesterday and put on GSB 3.2 and haven't had any problems installing apps. 3.3 just came out last night.
I haven't had time to try out Condemned's mod yet. The only drawback I see in GSB is the lag when hitting the home screen from an app or another screen.
Yeah, that was my primary complaint with GSB. It doesn't seem to be an issue at all with Condemned (using LauncherPro), but I'll see how it feels after a few more days of use.
That is supposed to be fixed in 3.3, with the new gscripts that Workshed includes. I haven't tried it myself.
I had the problem with both; it was always solved by going into settings->cyanogenmod settings->performance->lock home in memory, for both ROMs.
The only issue that I had with GSB is that it would usually fail on the first try for installing or updating apps from the market. Subsequent installs always worked. Otherwise, it was rock-solid. The last version that I ran was 2.9, though.
Because the current Condemned has an apparent issue with Navigation, I decided to try out GSB 3.4. I am no longer having those market issues that I always had.
Seriously, both ROMs are excellent. It almost comes down to this: if you prefer ADW launcher, go with Condemned. If you prefer LauncherPro (or, for now at least, need navigation), go with GSB.
I have never tried Tazz but I suspect that it is also excellent.
Condemned was able to fix the synchronization issue with the email exchange, which was a big deal to me as I use it for work and love having my email pushed to me right away.
Has GSB had success in this area?
Does flashing from one of these CM7 ROM'S to the other require a factory reset?
