Gsiff_daemon HELP!
OneZeoN
Hi
Only had my Note 3 for a week or so but today I noticed under my battery usage that this Gsiff_daemon thing has used 47% of my power!!
Any ideas what it is and how do I stop it or remove it???
My phone has not been rooted etc etc as I like to keep it standard.
I quick google search on the file/process name shows it is common to misbehave. It is a GPS process that seems to not be critical. If you are rooted, it has been suggested to rename it so it does not run. I have not done anything so don't take my word for anything. Search and good luck!
