a space between oem and ?...
fastboot oem ?
i finally stopped being lazy and just plugged in my phone.
Code:
c:\miniadb_m7>[COLOR=red]fastboot oem ?[/COLOR]
(bootloader) command list
(bootloader) get_identifier_token
(bootloader) checkSbl1
(bootloader) checkHWSecurity
(bootloader) keytest
(bootloader) heap
(bootloader) boot
(bootloader) reset
(bootloader) powerdown
(bootloader) rebootRUU
(bootloader) heap_test
(bootloader) gotohboot
(bootloader) rtask
(bootloader) task
(bootloader) enableqxdm
(bootloader) gencheckpt
(bootloader) readpid
(bootloader) writepid
(bootloader) readcid
(bootloader) writecid
(bootloader) readimei
(bootloader) writeimei
(bootloader) readsecureflag
(bootloader) writesecureflag
(bootloader) lock
(bootloader) list_partition_emmc
(bootloader) load_emmc
(bootloader) check_emmc
(bootloader) check_emmc_mid
(bootloader) read_mmc
(bootloader) load_modem_emmc
(bootloader) get_wp_info_emmc
(bootloader) send_wp_info_emmc
(bootloader) get_ext_csd_emmc
(bootloader) get_sector_info_emmc
OKAY [ 0.043s]
finished. total time: 0.046s
c:\miniadb_m7>
unfortunately,the command we want isnt there. some bootloaders have a command similar to "oem reset ruuflag"
looks like we are going to have to flsah something successfully to get out of ruu mode.
extract rom.zip from your ruu as i described here:
if your utility is corrupt,or your having trouble finding rom.zip,you can download a zip version of the rogers ruu from here:
Shipped ROMs
rename it to "rom" to make it a little easier on you.(dont type in .zip if using windows to rename)
now,put "rom.zip" into your adb/fastboot folder
flash rom .zip with these commands:
fastboot devices
fastboot flash zip rom.zip
it will prolly stop after flashing hboot with a "hboot preupdate!please flush again immediately" message. dont worry,this is normal. just enter the above again:
when its finished,you can
fastboot reboot-bootloader
fastboot reboot
just make sure you do not interupt the phone while its flsahing in the cmd window(that could be very bad)
hopefully that will fix it for you.
