Root [GSM] GSM 3VO Stuck In Bootloop
i have the same problem. my htc evo 3d(gsm) is stuck in a bootloop i tried to fastboot recovery it, but the console just says "< waiting for device >". any suggestions?
I moved your post here in the GSM section for proper support
Now post all your version info, what you have done so far and how you got into bootloop mode ?? ;) The more info you give us the better we can help you.
the info on your hboot screen will be particularly important,as will a link to the rom that you flashed.
also,how was the phone rooted?
bootloop sounds like your typical ics on gingerbread firmware error,the information you provide can confirm or disprove this...
i assume that you negected to make a backup that you can restore?
