Bradden Well-Known Member Sep 17, 2010 #1 Is there an app I can use to swich easily between GSM & WCDMA modes? I have quick settings app which will switch on/off but not between? Thanks
I ianb11 Android Enthusiast Sep 17, 2010 #4 CarsnGadgets said: extended controls Click to expand... That just takes you as a short cut to the menu though. Something 1 click would be easier.
SUroot Extreme Android User Sep 17, 2010 #5 Ive not found anything that doesn't take you to the menu option rather than doing it. It may be a limitation.
