Help GT-I9100G' does not support initialising
Hello ,
I am from india and my problem is when i try to update my firmware via KIES it says "GT-I9100G' does not support initialising"
The story starts here , i was updating my cell phone firmware through phone itself via GPRS as soon as it got updated it stuck on the boot , i resolved it through some of your posts but accidentally i downloaded GT-I9100's firmware and the condition got worse it booted with some icons on the screen , i again downloaded the GTI9100G firmware and through odin i installed it on my cell , it worked but now when i try to update through KIES it says "GT-I9100G' does not support initialising " .
some details you might require :
Android Version :2.3.6
Baseband version : I9100GDDKL1
Kernel Version : 2.6.35.7 dpi@DELL130 #2
Build Number : GINGERBREAD.XWLC2
PDA : I9100GXWLC2
PHONE : I9100GDDKL1
CSC : I9100GODDKL1
Please help
Hello and welcome aboard. Hopefully someone with this knowledge chime in to assist you. :)
I think that having a custom firmware (not stock) might be the problem? I know since I have a rooted, non official firmware that it won't allow me to upgrade either.
hi sweetfriend9
did you managed solve your problem? i'm getting the same error message.
i started an upgrade through kies on my home pc. after many hours of downloading, an error message came up and gave steps to follow to remove battery, replace, and boot up. Then it started downloading from scratch again. by this time i have run out of data. but the phone works.
now at work i'm trying to upgrade with kies again, but get message: GT-I9100' does not support initialising
PDA:KI4 / PHONE:KI1 / CSC:KI1 (XFV)
2.3.4
