Root Gt-p3100
devlister
i bought it in china, i'm using it right now, and i feel like a shit......i cannot access google play, the apps from china is soo few compared with google, it got autosoftware for cencorship, i cannot access almost anything, but i want to FLASH it and ROOT it, because this is the very first i'm using android plz help me! :(:(:(
anybody plz?!?
China is a very "special" country, I mean if you bought your tablet there sure it's preconfigured with high degree of censure, you should root it, but even rooting your device you will need manually install flash player because Adobe stop Flash support beyond 4.0 Android version. For both operations you will find enough info in this forum, just search topics. Please be careful when rooting, any mistake can cause you serious troubles.
