Help GT450 stuck at ANDROID Logo
tomasita
Okay so last night suddenly my lg cell phone said that the phone memory was full so the next morning i deleted some programs(games) i downloaded from the market but it still said the same so I decided to reset to factory settings but i accidently close my cell phone while i was sending a text to a friend so i couldn't do the resetting to factory settings... But when i opened it up it opened just like normal but then it stuck at ANDROID logo so i waited for it to load but it pasted like 3 hours then i turned off my phone... Someone pls help me i can't take it to somewhere im out of town someone help me pls! :(
You can try emergency mode, hold down Vol Down + Power On, you should see a blue screen saying "emergency mode", connect to usb and try flashing. I you use LG update, use the "Recover Phone" option.
Don't know how to help you further, in emergency mode the PC should see the phone, if not, probably either you have not installed the correct drivers, or the phone needs service.
Anyway, don't use the PC suite, you need the "LGMobile update" program, free to download from LG.
Forget PC suite, it is only good for normal Upgrades. If you got LG mobile working, go to "Customer Support" and select "Recovery Phone"
i did that but it didn't do anything it looked up my cell phone and asked did u back up all ur data and i said yes and it told me click contact for more information :S
WOW!!!
i let a kid play with my phone and he changed my unlock pattern then FORGOT IT!!!! i read the convo and pressed volume up+home+search and it worked!!!
SOOOO GLAD
SOOO HELPFUL
cheers
