Gtalk for Micromax A52
Even I don't have GTalk in my A52. Also there is a problem that when I reboot or switch off and on my phone the applications which I have moved on my SD card doesn't show. Though they are on the SD and they can be accessed through applications like ES File Explorer. But Why don't they show on the menu list directly??
That's a bug of default micromax launcher, install some other launcher from Google Play like ADW n u will have all your apps...i have checked n solved this personally on my friend's A52.
I was also facing the same problem...
Can you please tell me how to freeup internal memory in MMX A52??
