Dr_Zombie
Guide updated again to match
When I open the B2CAppSetup.exe , a box pops up saying "To check for software upgrades, you need to connect your PC to the Internet and press continue."
Get the official tool from the LG Support website. Then after it updates once via the internet use the Windows Enabler and hosts trick to block it, making sure that the properly configured shttps tool I have provided is running. To debug pull the status window of shttps by right clicking the icon in the task bar and viewing the Message log. When the LG Support tool runs you should see status messages in the Window as well as when the Flash tool is decompressing the KDZ you'll see it copying over to the shttps server via status messages.
If when you run the support tool the shttps server doesn't display the connection messages, you'll need to reboot as most likely the hosts file has not taken effect.
I
Additionally after the app setup updates it stays memory resident. So install it, update it, modify hosts, , reboot and then start shttps and then the LG Flash Tool 2014 in that exact order. Do not run the LG software update by itself afterward otherwise you'll need to reboot again.
Its a specific order.
hosts has to be modified after you initially clean run the program. Clear out your hosts line and tty again.
Don't worry. Im here to help.
Show me your hosts file. Attach it to your post if you can. I'll send you the corrected unmodified version back, and than another version what its supposed to look like when you modify it after the support tool
I was thinking about doing a video, I might make on in the future if I ever have to reflash back to stockhey man can you make a video please
Ive already unpacked the KDZ and have it all in a folder on my cloud. Letme know if that would help in any way...Thanks, I'm currently unpacking the 10e KDZ. To make this guide nil. Root injected, debloated...need a bit of help though...with the Android SDK...
http://forum.xda-developers.com/android/development/guide-root-method-lg-devices-t3049772
Or the windows enabler, I got the host file thing done fine.Hold down the Vol Up and the Power key until it says "LG" on the screen. Then release both of the buttons and immediately push them both down again until something new pops up. This will show you the next stepI hold down the volume up button and the power button but the phone just appears to keep rebooting and I don't get into any download mode, help?
Were you able to modify my hosts file yet? It still does not work. I feel I am not doing a step correctly. Ive tried following this guide but when I get to the LG Flash Tool part, it does not do what this guy says it would do. Idk if it might be because of the hosts file, but I do not understand the steps that I need to do, its confusing. Do you think you can clarify please? I am losing by mind of this lol its getting frustrating, I want to root so bad every since last NovemberDon't worry. Im here to help.
You mean Purple drake lite or LG-OneClick-Root? I've flashed firmware in the past but I'm trying to stay up to date on new root methods.No need to downgrade anymore
