[GUIDE] Easy way to get MSL without calling Sprint or using CMDA Workshop
DonB
♡ Truth, Justice and the American Way !! ♡ ™
Moderator
C&P From Kyouko ( Thanks )
Before doing this make sure you have aLogcat. You can get this from the Market
Also its easier to find your MSL if you go into alogcat and "clear log" before doing these steps.
First off I'll start by saying I have tried this on my phone , the official sprint update..
Anyway, I came across this screwing around a couple months ago when I wanted to reset my PRI, and apparently it still works with 2.1 roms.
Before
doing this make sure you have aLogcat. Also its easier to find your MSL if you go into logcat and "clear log" before doing these steps.
**Refer to the attached picture if you get lost**
  • So step 1 is to go to your dialer and enter ##DATA# or ##3282# which will bring up the EPST menu
  • Once the menu pops up just select "View Mode"
  • At this point you will see a screen with 3 selections.
  • From here either press and hold the Home Key and select aLogcat if you ran it before, go to your tray and run Logcat.
  • After opening Logcat it will update, once it finishes press "Menu" and "Pause" the log.
  • Then scroll until you see a group of entries labeled "I/EpstBroadcastReciever" which should be green
  • Locate the line that has "MSL Code=" at the end of it
  • Edit: Or press Menu and Filter "MSL" (thanks wjason)
And there you have it, your 6-digit MSL code without ever calling sprint or using a computer.
attachment.php
Nice work, but how is this easier than simply calling and asking for it? It only takes a minute...
Some cannot be bothered by calling and explaining the scenario of getting the MSL # to a rep and sometimes when you do get a rep some do not want to give it out, which has happened to some peeps, this eliminates the wait and explanation, just an option for the members
When you run the log the first time, how long does it take? I just downloaded the app after reading this thread. I have had my phone since February. It has been reading the log for 2 1/2 hours now. I have yet to be able to clear it.
Just curious if this is normal.
Press pause and then scroll down, but not sure about your carrier, this is for Sprint
I read in another thread that it wouldn't work for those still on 1.5. But, someone suggested the 0's and it worked.
Great info though. This has been driving me crazy and Cellular South will not give it out.
I use LG Marquee LS855 Sprint
I push ##3282#
but on the screen appear
data
data profile
browser
mmsc
multimedia
evdo
advanced
device self service
each menu has sub menu :
view
edit
What must I do for choice?
