I had a problem with the flash, other than having to run rebootRUU twice to get to the proper screen (kept getting FAILED (status read failed (too many links)) I didn't have any problems prior.
While running it the proper black screen with silver lettering it successfully ran the UZ,hboot / WP,hboot / UZ,boot / WP,boot but FAILED when beginning the image[recovery] unzipping & flushing...
I was in the process of renaming it and attempting to send to SD card when I realized I was in the wrong screen, here is the CMD log from that point:
c:\miniadb_inc2>fastboot flash zip PG32IMG.zip renamed it
< waiting for device >
sending 'zip' (292817 KB)... OKAY [ 49.299s]
writing 'zip'... INFOadopting the signature contained in this i
mage...
INFOsignature checking...
INFOzip header checking...
INFOzip info parsing...
INFOchecking model ID...
INFOchecking custom ID...
INFOchecking main version...
INFOstart image[hboot] unzipping for pre-update check...
INFOstart image[hboot] unzipping & flushing...
INFO[RUU]UZ,hboot,0
INFO[RUU]UZ,hboot,100
INFO[RUU]WP,hboot,0
INFO[RUU]WP,hboot,100
INFOstart image[boot] unzipping & flushing...
INFO[RUU]UZ,boot,0
INFO[RUU]UZ,boot,31
INFO[RUU]UZ,boot,73
INFO[RUU]UZ,boot,100
INFO[RUU]WP,boot,0
INFO[RUU]WP,boot,99
INFO[RUU]WP,boot,100
INFOstart image[recovery] unzipping & flushing...
FAILED (status read failed (Too many links))
finished. total time: 98.233s
c:\miniadb_inc2>fastboot reboot-bootloader
rebooting into bootloader... OKAY [ 0.157s]
finished. total time: 0.158s
rebooting...
finished. total time: 0.171s
c:\miniadb_inc2>
It appeared to run all of the updating on the RUU screen properly, but it did Bypass the [8] TP
I figured it worked, ran the final commands and moved on, boots up fine.
When I try to use revolutionary, however,
[edit]
I get stuck at:
"Communication with phone unexpectedly interrupted. Try again"
