dragg5inbody
Member
im with ya on this bro...im backing up my sd card right now to my computer but in the settings/ sd card shit i dont see anything for apps2sd to "check".......i was hoping to get this done tonight but now i dont know what to do..
WTF! I'm getting annoyed at this damn phone. Maybe it's user error? Can anyone list instructions on how to partition the sd card (i believe what the original poster said is how you do it). then place everything back on sd card. have a file explorer and search through the "a2sd-2.7-update3r1-signed" folder and download the .apk file
after it's installed reboot the phone. ether way i'm getting lost on this step...
9. Make sure you have Apps2SD checked under Settings > Applications. (You don't have to do this with some ROMs)
10. To check if you have partitioned your SD card correctly, go to Settings > SD card & phone storage > SD card secondary.
if i go to settings > applications i don''t see anything also....
in step 10. i never see SD CARD SECONDARY!??!!
I've followed the steps multiple times but it never partitions the sd card.
**edit**
***REVISED & Easier*** How To Install Apps2sd with Evil Eris 3.0 - HTC Droid Eris Forum
about to try that.
do i need to flash evil eris 3.0 with that update from that link? like flash it like a rom. like when i first installed evil eris 3.0? ((press up key and power button; go into boot mode and flash the evil eris 3.0 update to the system??? kind of like a rom? )))
damnit, i wish someone would just give me there phone number so i can figure this out.shrug
Ok, deep breaths. We can get it solved.
The update that he is talking about is the same file I linked to in my post. All you should need to do is flash that and it should start running.
In EE3.0 steps 9 and 10 won't work as it isn't set to show those things.
Try flashing the update and see if your available memory goes up on the phone.
So the problem you guys are having is that it doesn't say sd card secondary?
What ROM are you running dragg5inbody?
stock sense ui bro...i havnt done a rom yet and planned on going to w.w. tonight...but im not seeing that checkbox so i can do it...
You should probably install WW so you can get Apps2SD to work.
but i thought i had to partition the sd card before flashing w.w??
No, partition your SD card after you flash WW.
damn im dumb...
thanks bro,...so right after i flash w.w. from the recovery is when I choose partition s.d. card from the recovery screen as well?
if the screen is black and has been black for 10minutes can i just pull the battery out guys? !?!?
No, there is no boot animation in EE and the first boot takes long.
I would give it another 10 minutes and then if nothing changes pull the battery. You can always reload the the rom, update and a2sd fto the sd card from the recovery console. Don't worry, it isn't toast or anything.
If it won't load, just start from scratch and reflash everything.
right, i backed up everything before i killed it. i'm guessing after i did the kernel update i swiped the sd card so maybe that had something to do with it? i'm really not sure. this shit is annoying. anyways, the reason why it wasn't working was because i didn't flash the kernel update right?
What I did was flash WW, reboot, signed into Gmail, turned off my phone, then partition my SD.
...Ill letcha know how it turned out in a little bitThank you so much for the help...this forum is great and everyone is willing to help even the newbz like me...Ill letcha know how it turned out in a little bit
