sammyz
LG Whiz Kid
Ok so I have ported a few Gingerbread ROMs to the M and I ported BACKside to the C for you guys. Due to not much in responses I did not continue doing much more.
So if anyone would like to take this up to support everyone for the C, here's what you do:
1) If it is not an Optimus M ROM follow this: http://androidforums.com/optimus-m-...e-porting-lg-vortex-optimus-t-v-s-roms-m.html
BUT use these files: OptCUniV1.0_2.zip
2) If it is an Optimus M ROM you still need OptCUniV1.0_2.zip from above
AND all you need to port is:
In /system/etc replace:
apns-conf.xml
dbus.conf
gps.conf
hosts
media-profiles.xml
resolv.conf
vold.fstab
And in /system replace:
build.prop
After You flash whatever ROM you port:
To fix MMS (Flash this right over the ROM directly afterwards): Cricket-MMS-Fix_signed.zip
Details to implement MMS fix by PlayfulGod into your ported ROM are to come later![Smile :) :)](/styles/smilies/google/smilie.png)
![Wink ;) ;)](/styles/smilies/google/wink.png)
This has never been tried on Froyo ROMs. This WILL NOT work with ICS.
apns-conf.xml
dbus.conf
gps.conf
hosts
media-profiles.xml
resolv.conf
vold.fstab
build.prop
