Root [Guide] How-To Properly Decompile and Recompile apk's with apktool
There is new alternative to ApkTool + Dex2Jar + Jad!
Welcome open-source APK and DEX decompiler called Jadx:
[Links removed]
I get an error 'Could not decode arsc file' when running 'apktool.bat if MyAndroidApp.apk':
C:\apktool>apktool.bat if MyAndroidApp.apk
I: Baksmaling...
testI: Loading resource table...
Exception in thread "main" brut.androlib.AndrolibException: Could not decode arsc file
at brut.androlib.res.decoder.ARSCDecoder.decode(ARSCDecoder.java:55)
at brut.androlib.res.AndrolibResources.getResPackagesFromApk(AndrolibResources.java:315)
at brut.androlib.res.AndrolibResources.loadMainPkg(AndrolibResources.java:50)
at brut.androlib.res.AndrolibResources.getResTable(AndrolibResources.java:43)
at brut.androlib.Androlib.getResTable(Androlib.java:44)
at brut.androlib.ApkDecoder.getResTable(ApkDecoder.java:148)
at brut.androlib.ApkDecoder.decode(ApkDecoder.java:98)
at brut.apktool.Main.cmdDecode(Main.java:128)
at brut.apktool.Main.main(Main.java:65)
Caused by: java.io.IOException: Expected: 0x001c0001, got: 0x00000000
at brut.util.ExtDataInput.skipCheckInt(ExtDataInput.java:48)
at brut.androlib.res.decoder.StringBlock.read(StringBlock.java:45)
at brut.androlib.res.decoder.ARSCDecoder.readPackage(ARSCDecoder.java:97)
at brut.androlib.res.decoder.ARSCDecoder.readTable(ARSCDecoder.java:82)
at brut.androlib.res.decoder.ARSCDecoder.decode(ARSCDecoder.java:48)
... 8 more
Can someone tell me how to fix this?
Hi,
Since decompilation, modification and recompilation of apk required several commands so I created a java GUI tool APKRepatcher which helps you to modify an existing apk using a simple user friendly GUI. It lets you edit java/smali code from an APK and rewrite the changes back to the modified signed APK. Additionally, it provides you option to convert Dex, Jar, Class, Smali, Class from one format to another.
[Link removed]
Thanks
i wanted to change status bar icons colors...i followed the steps...recompiling succesfull...the problem is that 7zip cannot fully browse inside archive...folder res/values/ is not available to put back colors.xml...i tried to sign generated apk but i got a lot of UI fc and after restart the old systemui.apk is there.
did I do smth wrong??
Hi,
[Link removed]
Thanks
can I use it for changing statusbar icons color?
Just a note to say that Android Forums does not condone the use of APK decompilation tools, for the purposes of modifying original source code, with the intention of re-publishing, or otherwise using modified apps for financial gain, without the original author's consent.
Legitimate uses of this tool would include changing app appearance or preferences, for personal use.
If you wish to modify the app's source code, then approach the original developer first to ask them to change it, or obtain permission to do this yourself.
