Root [GUIDE] HOWTO: Build your own AOSP ROM
jdkoreclipse
First off, i want to say that this is information taken from various sources, the most predominant being start [CVPCS Android Wiki] and Get Android Source Code | Android Open Source . The only thing i contributed to this guide was that i condensed it a bit and customized it specifically for the inc.
WARNING: This is NOT FOR NOOBS. If you havent had much experience with working with the Android System, you should not even think about using this guide.
This is a guide for building AOSP on Ubuntu Lucid Lynx (10.04). If you have Mac, i cant help you much. If you have Windows, i strongly reccommend that if you havent already done so, download Ubuntu onto a CDROM and run wubi.exe to trial ubuntu.
THERE WILL NEVER BE A GUIDE FOR BUILDING ON WINDOWS!!!!!!!!!
Ok, so now that all that stuff is over, heres your guide:
First, we want to install java5. Java6, the newest java is NOT supported due to @Override incompatibilities
Code: sudo apt-get install git-core gnupg sun-java5-jdk flex bison gperf libsdl-dev libesd0-dev libwxgtk2.6-dev build-essential zip curl libncurses5-dev zlib1g-dev
You might also want Valgrind, a tool that will help you find memory leaks, stack corruption, array bounds overflows, etc.
Code: sudo apt-get install valgrind
Set the system to use the right version of java by default:
Code: sudo update-java-alternatives -s java-1.5.0-sun
Now to install the repo
Code: cd ~/
mkdir bin
echo $PATH
Download thereposcript and make sure it is executable:
Code: curl http://android.git.kernel.org/repo >~/bin/repo chmod
a+x ~/bin/repo
Create an empty directory to hold your working files:
Code: mkdir mydroid
cd mydroid
Run "repo init" to bring down the latest version of Repo with all its most recent bug fixes. You must specify a URL for the manifest:
Code: repo init -u git://android.git.kernel.org/platform/manifest.git -b froyo
When prompted, configure Repo with your real name and email address. If you plan to submit code, use an email address that is associated with a Google account .
A successful initialization will end with a message such as repo initialized in /mydroid
Now to download all the files you need.
To pull down files to your working directory from the repositories as specified in the default manifest, run
Code: repo sync
NOTE: The repo sync does tend to take a little long, after all it is 2.1 gigs of files
Now to verify the git tags. Doing this wont affect the build, but it doesnt hurt.
In your command prompt, type:
Code: gpg --import
and paste this LONG key into the empty space:
Code:
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.4.2.2 (GNU/Linux)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=Wi5D
-----END PGP PUBLIC KEY BLOCK-----
And press ctrl d to exit the gpg mode and verify the git tags.
Now to setup the vendor overlay:
Code:
cd ~/mydroid/system/device
cd htc
mkdir inc
cd inc
git clone http://github.com/koush/android_device_htc_inc.git inc
Code: cd ~/android/system/device/htc/inc
./extract-files.sh
NOTE: ADB Must be in your path. You also have to edit the extractfiles.sh so that it reads ./adb pull and not adb pull (add nix boxes)
Now to build the build:
Code: cd ~/mydroid/system
. build/envsetup.sh
lunch generic_inc-userdebug
make
Troubleshooting:
Ok, lets say you get an error. most likely its librpc. What you have to do is
Code: make clean
make librpc
Also, you may have to edit some files, add in some proprietaries, so whatch those errors carefully!
If the build fails because of java, enter this:
Code: export ANDROID_JAVA_HOME=$JAVA_HOME
export $PATH
You should have a nice AOSP build if all goes well!
Note from Staff: Attempt this at your own risk.
Good stuff. Only thing i wish, someone would create a guide like this for Mac. Or just a starter for Mac. Im assuming if i dual boot into Ubuntu from my Mac, it shouldn't be much different.
Dual boot is fine, or if you want, go to the first link I posted, follow the Mac setup guide, then use the rest of my guide.
Its cool. I have several links with guides to them on using a Mac.
Not too difficult,some have even said its easier. Not sure how or why, but anyways.
I'll take some of the tidbits from your guide as well as many others and get to work. I will not be doing anything for the Inc, but its good reading nevertheless :)
