This guide is only for LG P690, not LG L45C or LG P698!
Note, neither I nor Android Forums is responsible if you get your device bricked. Follow this procedure on your OWN RISK!
Please, read every line of the guide. Being careless can be dangerous!
Please note, all the files you'll be downloading, are uploaded on my Google Drive and there are nothing like surveys, so don't worry.
Now let's start:
-: Rooting :-
It's a complete guide for rooting LG Optimus Net P690.
1. You'll need a Microsoft Windows based Computer.
2. Download these required LG Drivers:
>> LG Android Driver
>> LG United Mobile Driver
>> Restart your PC after installing drivers.
3. On your phone, Check 'USB Debugging'. Path: Menu >> Settings >> Applications >>
Development >> Tick 'USB Debugging'.
4. On phone, go to Menu >> Settings >> Storage >> Uncheck 'Mass storage only'. If it is already unchecked, you don't need to do anything for this.
5. Connect your phone with PC. Phone will ask you to 'Turn on USB Storage'. DO NOT TURN IT ON! You should see these two messages on phone's notification bar:
1. "USB Connected"
2. "USB Debugging connected".
====Method 1: Using Unlock Root 3.0====
1. Download and install 'Unlock Root' on your PC from here: Unlock Root 3.0
2. Open Unlock Root and press 'Root' button, it may ask you to select online devices (devices connected with PC), just select LG P690.
3. Withing a few seconds, it'll ask you to reboot your phone, click on OK. When phone starts, go to menu and you'll find Superuser app there.
It means you're rooted now!
====Method 2: Using SuperOneClick 2.3.3====
1. Download the SuperOneClick 2.3.3 RAR Archive from here: SuperOneClick v2.3.3
2. Extract the archive and find the ADB folder in the folder you just extracted.
3. In ADB folder, press and hold Shift and right-click in any empty space and select Open command prompt window here from context menu.
4. Write following commands in the CMD window:
Code:
adb devices
adb shell
echo 1 >/data/local/lge_adb.conf
5. After entering above code, minimize the CMD window, DON'T CLOSE IT!
6. Now open SuperOneClick.exe from extracted archive and click on root button.
7. Your device will be rooted in few seconds and all done! You can close all windows now.
-: Installing ClockWorkMod custom recovery :-
Some new Android users may be wondering, what is ClockWorkMod Custom Recovery Image?
They can go here and find their answers:
What is ClockWorkMod Custom Recovery and how to use it on Android?
First, Your phone must be rooted.
If it's not rooted, use above guide of rooting.
1. Required downloads:
Step 1:
First, Download this all-in-one RAR file: Recovery Tools.rar
The RAR Archive contains:
1. Fast Boot (folder)
2. flash_image
3. recovery.img
4. MD5 Hash.apk
Step 2:
Now extract the archive and copy all files (except Fast Boot Folder) to the root of your phone's SD Card (i.e. /sdcard/) and install the MD5 Hash(MD5 Hash.apk) application.
2. Checking the MD5 Sum of 'recovery.img' file:
Now you must check the MD5 Sum of 'recovery.img' file.
First, What is MD5 Sum?
Answer: MD5 Sum of a file, is a string / series of characters that is used to check whether the file is corrupted or not.
Step 1:
>> Use MD5 Hash to do it.
>> Open MD5 Hash and select Calculate MD5 from file
>> Now click on ... button, browse to /sdcard/recovery.img and press 'Select button'.
>> Then click on Calculate MD5.
Step 2:
Compare the calculated MD5 with this MD5 Sum: 258e95cd2a697d902c2c139893d83063
(Now see if both the sums are same. If not, download the recovery.img and try checking MD5 again.)
REMEMBER, BOTH THE MD5 SUMS MUST BE SAME OTHERWISE YOU AND YOUR PHONE WILL DIE!!
(Different MD5 Sum means the recovery image is corrupted.)
3. Flashing the recovery image:
====Method 1: Using a Microsoft Windows based Computer====
NOTE: If you're browsing with your phone, you can directly flash recovery image without a computer. Just skip to alternate method.
Step 1: Enable USB debugging: Menu >> Settings >> Applications >> Development >> USB Debugging.
Step 2: Open the Fast Boot folder, press and hold Shift and right-click in any empty space and select Open command prompt window here from context menu. Then type adb shell in the CMD Window.
====(Alternate) Method 2: Using the LG P690 Phone====
(Alternate) Step 1: Download Terminal Emulator from Google Play Store.
(Alternate) Step 2: Open Terminal Emulator.
Step 3: Now type following commands (green colored) one by one in CMD window / Terminal Emulator:
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock1 /system
cat /sdcard/flash_image> /system/bin/flash_image
chmod 755 /system/bin/flash_image
mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
mount -o remount,ro -t yaffs2 /dev/block/mtdblock1 /system
flash_image recovery /sdcard/recovery.img
reboot recovery
Note!: The command, mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak will give an error: No such file or directory. Just ignore the error and continue.
Now your phone should boot into CWM.
* And.. TADA! The ClockWorkMod Custom Recovery is now installed!
*How to boot into CWM? : Turn off your phone completely and hold Power + Volume up + Home buttons together about 5 to 7 seconds.
Touch not working! How to navigate? :
Volume + = Move up
Volume - = Move down
Power / Search = Select
Back = to go back.
Tips and Warnings:
Tips:
Tip #1: Install Busybox:
Busybox is a wonderful collection of UNIX Operating System's useful tools. It's a must!
Link:https://play.google.com/store/apps/details?id=stericson.busybox&hl=en
Tip #2: Nandoird backup:
Now you are rooted and have a custom recovery image installed.
Means you have access to file system of Android.
So, any system file can be accidentally deleted and it can cause a fatal error or worse!
And you know, taking a backup is always a good habit.
You can also backup whole Android system!
To do so, boot into recovery, then go to Backup and restore and select Backup.
Now whenever you experience any problems with OS, you can reinstall your OS by restoring the backup!
Tip #3: Uninstall some crappy system apps:
You can use Root Explorer to do it.
System apps' APKs are located at /system/app
Recognize the app you want to uninstall by its icons.
Put '.bak' behind the '.apk' extension.
For e.g., To uninstall Finance, rename it to Finance.apk.bak (orginal: Finance.apk)
These apps are safe to uninstall:
1. LG Remote Call
2. Email (not Gmail)
3. Finance
4. LG World
5. Smart Share
Whenever you want any app back, just remove .bak and you're done!
Warnings:
Warning #1: Factory Reset
You have installed recovery image so you need to be very careful!
NEVER USE PHONE'S BUILT-IN FACTORY RESET OPTION. IT'LL BRICK YOUR PHONE!
If you need to perform a factory reset, it's available in recovery.
Warning #2: Bad Message "recovery "
Every time you'll boot into recovery, it'll give the above error!
Hey! Don't doubt yourself! You just flashed it fine!
Yeah, that's also a standard error. Just ignore it.
All the Best.
