*This has been patched in 4.3 and only works 4.2.2 and lower*
Upon helping a member with another issue, I came across a tool that allows one to root & unlock the Nexus 4 without data wiping. It is also a method that doesn't require a connection to a computer. How Cool! :smokingsomb:
Framaroot is a 1-click root method without the need of tethering the device to a computer. Simply download the apk, install, and run it to obtain root.
Once you're rooted, that allows you to use BootUnlocker for Nexus Devices to lock or unlock your bootloader without the need for the complete data wipe.
This will hopefully be of use for some people out there
